Strengthening Sheetmetal
I am using 26ga. sheetmetal (9-3/4 wide) with two tabs welded (for self tapping screws), however, the the srews are torqued the sheetmetal bends. Will placing a groove across the width of the metal (over the top of this section) provide enough strength to overcome the screw torque? Can anyone provide me with some suggestions and/or forumlas to determine this?
RE: Strengthening Sheetmetal
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
Gussets, unfortunately, are not an option due to space limitations.
Sorry I have no idea about formulas for this.
I hope that helps
ps I am guessing the reason you are welding tabs instead of forming is because you will get no threads in 26 gage.
