Standard for Painting specifications
Various standards are available for referring type of paints & their applications for equipment & piping in a large size process industry. Any gentelman in the forum to assist me as which 01 is the best standard to be referred & should be procured.
RE: Standard for Painting specifications
Base metal
Operating temp
Insulation, or lack of
Probably no oh-one best, but you might check with Anchor, Carboline, Ameron, etc.
Mike
thanks for your reply. However i was referring to the standards need to be referred for selection of paints, their application & application procedures.
The suppliers are not important for me. we have many of them. every one claims to be the best.
Pressure vessels
Off-SITES Storage Tanks
Structures
Tanks
Piping
Pumps
On each item you should establish temperature services insulated or non insulated equipment.
After that classification you should contact paint fabricators such as the ones SnTMan said or others such as Hempel and International Paints.
For each equipment service, according the location of you environment (next to the sea or not) they will help you to specify the best painting system according your needs.
luismarques
http:/
I would dig around on this site. Will lead to numerous requirements.
sounds a useful site
Steve Jones
http://www.pdo.co.om/pdo/
In the company where I work, we use the SSPC standards end the paint's data-sheet for defining the bid terms in paint contracts.
Javier Guevara E.
Projects, Mechanical Engineer
TERMOGUAJIRA - GECELCA S.A. E.S.P.
