Methanol usage in drag vehicles
I have purchased a drag vehicle which is set up to run Methanol.  This is my first foray into the world of alcohol and would like to gain more information on running the fuel such as tuning and various fuel flow rates.
It is a carburated system on a big block chevy.
Any help will be greatly appreciated
RE: Methanol usage in drag vehicles
You need to flow about twice as much fuel for the same weight of air when compared to petrol.
The methanol will not colour the porcelain of the plug tip like petrol does, so you tune by discolouration of the metal of the plug.
You should use cadmium plated plugs and see how the cadmium burnd of the metal at the earth strap and the plug threads.
An ideal tune will show heat discolouration of the earth strap to about thr bend in th strap and will show heat to about 3 threads up the plug at the earth strap side of the plug.
You need fresh plugs for each test as once effected by heat, the colour won't return to original.
The threads are more effected by A:F ratio and the earth strap more effected by ignition lead, however each effects both to some extent.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
