oring seal
oring seal
anyone has experience with oring sealing .
We have oring seal on butterfly valve disc. Flow push oring outside its groove.
there nay construction solution to solve and void this problem?
valve is used with water at max 6 bar
in the valve is generated quite hi velocity ...about 1,5 mxsec
henry
henry
RE: oring seal
RE: oring seal
what are the current groove shape and o-ring material & section?
I believe there is a proper geometrical design and material selection capable of preventing extrusion of the seal... try also consulting o-rings Manufacturers catalogues and asking the question on the forum819: Mechanical Seal engineering within this site.
caihui,
I think that the valve in object is most probably a "standard" or high-performance butterfly valve (i.e. with no more than two off-sets), as the triple-offset rotary valves are usually metal seated (and then disc gasket is a metal spiral wound one).
Hope this helps, 'NGL
RE: oring seal
RE: oring seal
- h
- htt
- http://www.ponnmachine.com/ > > MATERIALS > > Groove Design.
RE: oring seal
henry
RE: oring seal
Bye, 'NGL
