Custom Tools Advanced Machining
Can anyone direct me to anywhere I can find out how to model & use a custom cutter in Advanced Machining. Catia is very limited to the types of cutter you can use. I've had a look at the help files etc but can't find anything
RE: Custom Tools Advanced Machining
What type of modification are you looking for? you could always use User Representation to visully see the form cutter while programming.
I would like to create a custom Bull Nose Type Cutter that taper from Dia 20mm To Dia 16, to cut inside a closed angle.
I don't just want to create a representation because the tapered part of this cutter will be used for scanning some areas of the part, that & I'm also not sure how to do this. I also need to create custom cutters that are used to form shapes.
I'm afraid after much searching and discussion with several support companies and Dassault directly I have come to the resolve that most custom cutters cannot be defined in Catia. Especially ones that you would like to use for tanto type operations.
This would be a huge improvement request from us NC guys using V5.
Thanks NCProgrammer you confirmed what I thought. Wouldn't it be good if you could just model the Tool up & Catia used it to generate the cutter paths like most other CAD/CAM Systems!
User representaion is ok for video replay but I have Vericut for that!
