CONVERT A PART CREATED USING PRO-E TO CATIAV5
CAN SOMEONE HELP ME AS HOW TO CONVERT A PART CREATED USING PRO-E TO CATIAV5.THE RESULTING CATPART SHOULD HAVE SAME AXIS AND SAME ORIENTATIoN AS IT WAS HAVING IN PRO-E.I have already tried it by converting it step and iges, but the problem is the default axis is getting changed and as a result am getting the model in catia with different orientation. i.e Y axis in pro-e is getting converted to Z- axis in catia,therefore I tried by creating a new coordinate system in pro-e  and selecting the created coordinate system while converting it to *step* format. But still i am not getting the same orientation.I think The axis system which i am creating i pro-e is not the right one. Can someone help me in this issue!
Please elaborate the steps you have followed.
This thread has also rised in catia forum also!
RE: CONVERT A PART CREATED USING PRO-E TO CATIAV5
Double-posting a topic is a no-no.
I'm not familiar with CATIA, but when I run into the same situation with Pro/E, I usually need to make a new coordinate system in the recipient part.
Again I don't know how it works with CATIA, but try to make a new coordinate system in that model and reference it when you do the step import.
Create a ne CSYS in top level with a differnt axis orientation and when you export as STEP then select this CSYS.
-Hora
Thank you very much for your reply,
but i am just confused of creating the new coordinate system in pro-e so that it is exported ssame as in proe.
If you try for a small example , you will get a very clear idea
For your csys to use to export create one by doing a copy-paste special selecting apply move/rotate using the DEF_CSYS
Axis   Value
X-Axis -90 and
Y-Axis -90
This will create a CSYS with the
X pointing Down and Left     /
Y pointing Down and Right and    \
Z pointing Up when shown isometrically |
  z
x   y
ProE, UG, & Catia,  each have different default Coordinate Systems and Isometric orientations as shown below. Opening files and exporting them for 3D Adobe presents similar issues.
Michael
wavey3
In yor top level assy, create a CSYS using an existent CSYS (Offset and rotate axes) or using the 3 default datum planes and put the z axis as you want to appear in CATIA. Then select this CSYS when you export the assembly.
Please nothe than ProE and CATIA have y and z axex switched.
-Hora
Hora and mjcole,thank you very much for your solution, i think i have solved this problem, by your help.
I think you have saved lot of time.
thanks again
