Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I am very happy with the whole site and would like to extend my compliments to all of you who work to make it one of the most useful sites (If not THE Most Useful) ...and the easiest to navigate..."
Geography
elogesh (Mechanical)
1 Aug 07 3:34
Dear all,
This is regarding plastic flow simulation using mold flow software.
We have a problem while running analysis with mold inserts,
We tried following two approachs
Approach 1
We meshed mold insert and the plastic part togeher as a single integral part in Meshing software (Hypermesh). Then in MF, we selected appropriate insert surface elements in fusion mesh as mold insert and assigned properties for it .when we fired the analysis in molflow, free edges were indicated after completion of flow,cool analysis and the warpage analysis was failed.The error indicated was free edges along the interface region between insert and plastic area.
Approach 2
In second iteration, By using fusion mesh option,we meshed the plastic volume and meshed seperately the insert volume.now when i check for free edges, Mold flow clearly indicates there are 400 free edges and overlap which is exactly at the interface area.i want to run the full analysis  including warp.now the mesh has a good connectivity between both the plastic area and insert area.
We are clueless and look forward for suitable directions to proceed further.
E.Logesh
mjh368 (Chemical)
1 Aug 07 10:52
I do not fully understand what you are trying to do..
What is the insert?
If it is not plastic why do you have it in mold flow?
I think i would used a model that only represented the plastic peice of the total part.
Not sure what you are hoping to get from the "connectivity" between the peices.
I would set my cooling etc up with the mold properties and temps and the treat the insert region as a different type of steel BeCu etc and observe cooling/warp variations that way.
I could be off cause i dont know exact what your doing but just thinking out loud hope it helps.
2 Aug 07 4:39
Hi Mjh,
Pl. do google search..You will get relevant details.
Also pl. refer this link,
http://www.3dshapes.com/moldflow-insert.html
We already resolved the insert modelling problem and we will share the details in next thread.
Logesh.E
Close Box
Join Eng-Tips® Today!
Join Us             Close
