Ellipsoidal V.S Torispherical
Dear All,
I have a vessel with ID=3500mm,DP=55barg, DT=300c,my recommendation for head is 2:1 ellipsoidal but our fabricator considered an approximation based on UG32(d)with knuckle radius0.17D and a spherical radius 0.9D.Thats acceptable but for thickness calculation he has applied 0.9D instead of D at ellips. formula.whats your idea?is it correct?and why?
Thank you very much
RE: Ellipsoidal V.S Torispherical
No, of course it isn't correct.
D is, as defined in UG-32(c), the inside diameter of the head skirt, and stays as such. The approximation permitted in UG-32(d) is only a matter of how to fabricate the head and of checking its shape, the calculation stays exactly as if it was an ellipsoidal.
prex
http://www.xcalcs.com : Online tools for structural design
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
Dear prex
I asked him about this matter and the fabricator clarified that he applied K=0.9 in the ellips. cal. formula with the specified h.is this a correct answer?
All they have to do is apply the code formula.
By the way there is no h (height?) in the formula, so can't understand what they are doing.
prex
Dear prex,
depth of head (h) is 958mm.
So it is not a 2:1 ellipsoid, as the depth would have to be close to 1750 mm.
Can't comment anymore without some clear and complete data.
prex
Sorry, the depth would 875 mm of course.
As this head is deeper than a 2:1 ellipsoid, it may be true that its thickness is lower, but to prove this according to the code the correct procedure is in 1-4.
prex
