Noise of air released to atm.
How do I calculate the noise generated when air is expelled from a 1" pipe open to the atmosphere. Air is at 132 degrees F at a pressure of 2 psig inlet and 0 psig at the outlet, and ambient temperature. Velocity is 35 ft/sec.
This comes about when a tank is under 2 psig pressure, and is vented to the atmosphere when the tank is being filled. The dry air vented into the tank is through a regulator set at 2 psig.
9751jld
9751jld
RE: Noise of air released to atm.
but you may post it on the aero forum and see what those folks have to say.
noise of jet exhaust (much higher velocities, i know) are generated i believe by shear of adjacent air streams.
regards
magicme
there's no place like gnome.
