How/Where do I edit the config.pro file
I'm not sure where and how to edit my config.pro file to change my tolerance display mode to "yes". mode "normal"
I would like this change for all drawings I create so I will not have change the file for each drawing.
Danoo
Danoo
RE: How/Where do I edit the config.pro file
The drawing.dtl file is where the option needs to be set for drawings - the config option to point to the file is
drawing_setup_file your folder\Default_drawing.dtl
To create the file, right-click on the background of the drawing & select Properties -> Drawing Options - you can then save the file. This file will only be used if you don't use a drawing template - if you use a template, you will need to save the template with the option set correctly.
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"First they ignore you, then they ridicule you, then they fight you, then you win." - Mahatma Gandhi
