PowerPoint and eDrawings question
I am trying to create a powerpoint with embedded edrawings. The problem that I am having is, when I send it to another computer, it won't show the slides with the edrawings files on them. This is the first time that I have dealt with Powerpoint, so I have no idea where I need to go.
Does the computer that I am sending the file to need to have edrawings installed on it? Because it doesn't.
I am looking to send this to a customer.
Thanks in advance.
B. Long
Dell Precision 380
P 4 2.80 GHz
2.5 Gig Ram
Solidworks Office 2007 Sp. 2.2
AutoCAD 2005
RE: PowerPoint and eDrawings question
It would make sense that the pc would need edrawings on it. It's like embedding a quick-time movie and the receiving pc only has windows media player.
What is it you're trying to show via edrawings?
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
If you drag and drop the eDrawing file into PowerPoint, it should show. If it doesn't, double-click on it in PP.
After you have it, right-click and select "edit", you can animate it.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
<<Does the computer that I am sending the file to need to have eDrawings installed on it? >>
In my experience, yes the computer that you want to have the PowerPoint presentation run on has to also have the eDrawing application loaded.
This being said, supposedly you can send an executable eDrawing html file, but I have not been able to make this work within a PowerPoint presentation. Also, some firewalls block executable files.
ExpTec
DBA
Experimental Technique
