AutoCAD Internal Error
When trying to explode an object, a screen popped up with the following message:
INTERNAL ERROR: !dbblkref.cpp@3541: eNullObjectPointer
What can I do to fix this? Thanks!
RE: AutoCAD Internal Error
1. which ACAD-version?
1a. Any applications?
2. which objects?
3. Every *.dwg or only one?
4. Did you try the "_audit"/"_recover" command?
Lothar
ADT 2004
Thanks for responding. Below are my answers to your questions.
1. I am using ACAD LT 2006.
1a. Are you talking about other applications that run on top of AutoCAD? If so, then no. I am running stand-alone.
2. The object was blocked and sent to me by a customer.
3. This is the only drawing with this error.
4. I have not tried the audit/recover.
Using AutoCAD Mechanical 2006, UGNX4, XPsp2, MSOffice 2K3
http://mechcad-insider.blogspot.com/
"The fear of the Lord is the beginning of wisdom"
