Need advice on simple FEA task
I need to compare the strength of a .5" OD, .040 wall tube made of 4130 with that of a .55" OD, .079 wall tube made of 6061 (the same length, about 4" long). Think of a telescopic motorcycle fork in miniature and you have a good idea what the setup is. I know the bend will be concentrated just below the lower triple tree (or yoke), but it would be helpful to know the approximate force required to bring each material to the yeild point.
I attempted to use COSMOSXpress, but my computer crashes after every attempt. On top of that I'm not so sure I'm setting things up correctly, or that the simulation can be done with COSMOSXpress.
Lives are not on the line with my products, and I don't usually need to do this type of work. However, I'm working on a new product and knowing this basic information could save me some headaches.
Provided I had a computer that could do this without crashing, will COSMOSXpress do the simulation?
TIA
QB
TIA
QB
RE: Need advice on simple FEA task
What are the yield stresses of the various materials you are considering? There is often a very wide range of yield stresses even for the same alloy, say 6061, but with a different heat or temper, say T351. Which materials and heat/tempers are you considering?
Maybe, if you can model the constraints correctly.
As it is a tube in tube type loading it will actually fail in a fairly complex fashion, involving contacts, which CX won't handle, but with a bit of thought you should be able to get close.
Try running some of the tutorial models so that you can prove to yourself that it is not an installation problem. Assuming those work then the next problem is to figure out what is wrong with your model. Having said that I'm surprised a modelling error crashes the whole program.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
(and unless there is a LARGE difference in allowable stress, the larger thicker tube is stronger)
Cheers
Greg Locock
