Pipe Sizing Tool
Pipe Sizing Tool
Is there any pipe sizing tool for the field. Where you could just attach it to the pipe and it would tell you the size of pipe and schedule? All I could find is www.pipesizer.com , but the website looks amateur and I am not sure I want to send money without a valid website. Sometimes it is hard to tell the difference between a 3 and 2-1/2" pipe. Or how do you measure pipe sizes? Please, share your wisdom.
RE: Pipe Sizing Tool
http://virtualpipeline.spaces.msn.com
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
https://www.pitape.com/Default.aspx
These are tapes for doing the same thing with a loss in precison.
http://www.perfecttape.com/tape4.htm#diatape
http://w
20tape.htm
http:
When flanges are not available then a piece of string (or wire) as GSTeng said works just fine
saludos.
a.
