NFPA-70E Table 130.7.c.a question
Ok, I am fairly new to the arc flash issue so I am hoping to get some assistance from the more experienced engineers out there.
In the table notes, it mentioned clearing times of 0.03sec (2-cycles). What devices clear in 2-cycles (other than fuses)? Does this include breaker operating time?
I am just trying to fully understand this 2-cycle note. Thank you in advance for the advice.
RE: NFPA-70E Table 130.7.c.a question
"Clearing Time" includes all time from initiation of the fault until the arc is extinguished (and stays extinguised).
What about if the bolted fault current is not in the instantaneous region of the breaker? I would think you need an arc flash analysis to know if this is the case or not.
As a rule of thumb, the smaller the transformer, the more problems you will have.
For 208 V systems, there is a statement in IEEE 1584 that only transformers 125 kVA and larger need to be evaluated. That's probably the origin of the option in SKM.
