Stormwater Planning
Stormwater Planning
Hi.
I work for municipal government in Ottawa, Canada. We are commencing preparation of a "stormwater management planning guideline" to direct land developers in preparing high level studies supporting land development. Basically, how to move from a subwatershed study through to a stormwater management master plan ensuring that all bases have been covered.
I am looking for tips of web available examples. Has anyone recently prepared such a guideline, or use an existing guideline as a frequent reference?
Thanks.
Thanks.
RE: Stormwater Planning
See also, PDHOnline.org Eclectic Hydrology.
Also PLEASE, assign some experienced people to develop your standards and have them peer reviewed.
good luck
http://www.novaregion.org/fourmilerun.htm
I generaly use Centre for Watershed protection (www.cwp.org). However, Ontario Professional Engineers have a "how-to-write a water report guideline" in the works, with the intention of expanding this into other areas. You did not say if you are a P.Eng or not but I suggest that as you are in Ottawa you could interface with PSC so that it gets some additional circulation and teeth.
If you have problems or don't know how to proceed contact Denis Dixon at ddixon@netrover.com he's been around the block both with Government and PEO as a Councillor at large.
Some responders here seem to believe that a Master Plan is the same thing as a set of design standards. They are not the same , although each has a useful purpose.
good luck
"The model contains an extremely precise, calibrated representation of all significant details which affect stream flows anywhere in the watershed. The physical watershed and the rainfall event are represented in detail through a long data file of model inputs. The model simulates ground cover, drainage path and type, infiltration, slope, and just about anything else that can affect stream flow. Armed with this information, model output is generated for different storm conditions, development patterns, or any other scenario of interest to planners and engineers.
The Four Mile Run Model provides NVRC's planners with information on how well the localities are complying with the federal mandate to ensure the effectiveness of the federal Flood Control Channel built by the Army Corps of Engineers. NVRC's computer model contains enough detail to provide accurate hydrographs for over 200 channel and pipe segments in the watershed. Over the years, its accuracy has been extensively calibrated and verified."
It is my understanding that; whenever a land use change is proposed, one must furnish new data for the area in question for evaluation in the model. The agency itself makes the model edits and runs the master model (one pays a fee for the agency to do this analysis.) The land use change approval is based on complying with the master plan goals.
