water modeling
water modeling
I am modeling a water system for a subdivision and I need to set my tank elevation from the pressures I have from a fire flow test. My question is which pressure do I use and why? residual or staic?
Thanks for the help
Thanks for the help
RE: water modeling
If you cannot meet the required residual pressure you may have to increase the pipe size.
RE: water modeling
good luck
