Showing High/Low tolerance while in drawing
I have several drawing and am trying to show the Hi/Lo tolerance on the dimensions. I've been told it can be done, but cannot figure it out. When I go into the edit mode, the tolerance mode button is grayed out. The text area shows "As Is". If someone can tell me a work around, it would really help.
Danoo
Danoo
RE: Showing High/Low tolerance while in drawing
tol_display yes
tol_mode nominal
and add the following to your drawing dtl file ( found by right-clicking on the background of the drawing, & selecting properties)
tol_display yes
