Adding currents of two or more feeders
Hi all!
I have a situation where I have to add the currents of 2 different feeders while using only 1 meter. One is fed by a 800 A breaker and the other by a 150 A disconnect switch.
Is it possible to use 2 CTs in series to do that? Or in parallel (I don't think so).
Now I know this sounds like an exam question...it's not
I'm waiting for your comments. Thanks
RE: Adding currents of two or more feeders
But, you have to use same ratio in both CT:s. You cannot use 1000:5 (or 1000:1) and 200:5 (or 200:1), which would be the obvious choice. Instead, you have to use 1000 A primary for both CT:s.
There are also "summing transformers" if you feel more comfortable that way. But an extra transforme eats your error budget.
Gunnar Englund
www.gke.org
If I had 3 feeders, 800, 400 and 200 A, I would use 3 1400:5 CTs, or a more common ratio 1600:5.
Thanks for your help all!
Right?
No, see again recommendation of Gunnar and Dpc.
You need put 3 sets of CT with ratio 1000/5A or on each feeders CT with same rato ( of course accordintly to max feeders ratio)and after will connect secondary in parallel.
It's not important number of feeders.
Regards.
Slava
and enter 1000A as the CT primary
The relay will see the sum of the currents in the 3 feeders
For example : 800+400+200=1400A
Take in account that you have full load, that means in this case prefer use 1500/5A CT.
But in this case you have another problem: accuracy of CT
in case of load <20% of CT ratio, your meas have high errors
If it's protection relay it's another case.
Regards.
Slava
BTW, in case of multifeeders meter, see some brunch meter
BFM136
http://www.satec.co.il/
For my pinion not bad solution.
My post,it's only example for calculation ( I'm only assume that max load is 800+400+200 and min load is 200A).
1.User need calculate max total load of all feeders and min load of smalest feeder.
2. what is a user target, only power metering or some biling data.
3.I think ( not sure), meters with 5A nominal have 10A max continuos current.
4. Of course metering class CT.
With these 4 points user can build any system.
Regards.
Slava
