saddle shall be designed with transit condition
Dear all of gentleman group
I got a problem when I designed for saddle by compress because my client required as per below:
"Saddle shall be designed for transit condition, until final figures are confirmed the accelerations in terms of g(g=9.81 m/s^) are as follows(Longitudinal +/- 0.28g)(Transversal +/-0.49g) (Vertical +/- 1.4g)"
I cannot find to input by compress. Please advice to me if you have any suggest.
Thanks.
RE: saddle shall be designed with transit condition
baonguyen,
You have to do some old fashion hand calculations to calculate the longitudinal and lateral loads and then apply the loads to the saddles.  Force =mass x acceleration.   Refer to Dennis Moss book, it has the calulations to lead you through this.
baonguyen,
PV Elite software for design of pressure vessels has this  input as G loads under seismic loads.
I'd answer, but apparently it was not adressed to me.
(grin).
Shannon
*** original post
baonguyen (Mechanical)
30 Jul 07 6:41
Team Member:
Engineering Tools for this sloution [Saddle Pro. www.Paulin.com].
L S THILL
Thank you very much for all of you. I have tried as per your advice. I really learn so much from your experience.
Have a nice day.
Best regards,
