Question on 2007 Release of ASME Sec VIII Div 1
If i enter a contract on December 15 2007, with user of pressure vessel, who specifies that latest edition of ASME Sec VIII Division 1 needs to be applied, should i use ASME Sec VIII Div 1 2007?
RE: Question on 2007 Release of ASME Sec VIII Div 1
On 12/15/06, the 06 Addenda to the 04 Edition was mandatory.
This information is contained in the Foreword of each Code. Words that state the following...........
After Code revisions are approved by ASME, they may
be used beginning with the date of issuance shown on
the Addenda. Revisions, except for revisions to material
specifications in Section II, Parts A and B, become mandatory
six months after such date of issuance, except for
boilers or pressure vessels contracted for prior to the end
of the six-month period.
It should be noted that by using vague terms such as the "latest edition" or "latest approved edition", or "latest accepted edition" or "latest adopted edition" in contract documents, there is quite alot of room for interpretation depending on the regulatory or enforcement authority in charge of administering the requirements.
In My Opinion......It is always best to indicate the year of Edition AND Addenda as applicable. It will save yourself from the hassles of interpretation later on. But that is just my opinion. Be prepared to defend your position in any case.
Should we consider the postmark date when contracts are mailed? etc......
There are three kinds of people in this world; those who can count and those who can't.
So if the date on the cover of the '06 Addenda is July 1, 2006, how do you get to that addenda being mandatory in mid December rather than 1 Jan 07?
I would take the position that the '05 Addenda would be in effect in mid December '06. However the '06 Addenda may be used anytime after its issue date. Maybe I fall into the category of "...those who can't."
Bmoorthy-
Was there some change which impacts the vessel in question or is this mostly about paperwork?
jt
Cheers
gr2vessels
Yes, you are correct, you have applied the rule of six months and have passed the test.....
