Dimensioning Problems
Hi all.
Its almost the end of the day Friday and Im back bothering you again.
Ok...here goes...
Here’s what I know about SolidWorks dimension names so far:
1. SolidWorks generates a name for each dimension, which is based on the sketch or feature in which it appears, such as
“D1@Sketch1”.
2. Dimension names can be displayed on a drawing by selecting “Show dimension names” in the System options window.
However, the “Show dimension names” option does not actually display the full name - you only get “D1”, not
“D1@Sketch1”.
Our goal is to have a unique name generated automatically by SolidWorks for every dimension on the drawing. The problem I’ve
encountered is that there could be 10 sketches/features for a part, and for each one the first dimension will be “D1”. Therefore, you’re
going to see 10 dimensions labeled “D1” on the drawing. (I know you can click on a dimension and manually change its name, but we
really don’t want to do that.)
So here’s what I’d like to know:
1. Is there a way to have SolidWorks show the full dimension name? (This would make each dimension name unique.)
2. If it’s not possible to see the full name, is there a way to change how the dimensions are named? For example, instead of
starting at “D1” for every sketch/feature, it would be nice to have SolidWorks continue from where the last
sketch/feature left off - if the last dimension name in Sketch1 is “D5”, how about the first dimension name in Sketch2
being “D6” (instead of “D1” again)?
3. Is there a way to control where the dimension name appears? By default, it appears below the dimension value – can this
be changed?
I would greatly appreciate any assistance you can provide in regard to these issues.
Ok...here goes...
“D1@Sketch1”.
“D1@Sketch1”.
be changed?
Rip
SolidWorks 2007
SP 4.0
RE: Dimensioning Problems
CODE
Dim swDoc As SldWorks.ModelDoc2
Dim swDwg As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim swDispDim As SldWorks.DisplayDimension
Dim swDim As SldWorks.Dimension
Dim swTol As SldWorks.DimensionTolerance
Dim xlApp As Excel.Application
Dim xlSheet As Excel.Worksheet
Dim xlBooks As Excel.Workbooks
Dim CurRow As Long
Const STARTROW As Long = 3
Const DIMNAMECOL As Long = 2
Const DIMVALCOL As Long = 3
Const DIMTOLTYPECOL As Long = 4
Const DIMUPPERTOLVALCOL As Long = 5
Const DIMLOWERTOLVALCOL As Long = 6
Const DIMTOLFITCLASSCOL As Long = 7
Const TOLSCALEFACTOR As Double = 1000
Sub RenameAndExportDims()
Dim NumTolVals As Integer
Dim TolIsFit As Boolean
Dim DimNamePfx As String
Dim DimNameIndex As Long
Set swApp = Application.SldWorks
Set swDoc = swApp.ActiveDoc
If swDoc.GetType <> swDocDRAWING Then
MsgBox "This macro only works for drawing files."
Exit Sub
End If
DimNamePfx = InputBox("Please enter the desired dimension name prefix")
If UCase(DimNamePfx) = "D" Or DimNamePfx = "" Then
MsgBox "Prefix not acceptable - aborting"
Exit Sub
End If
DimNameIndex = 1
Set swDwg = swDoc
Set xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
Set xlBooks = xlApp.Workbooks
xlBooks.Add
Set xlSheet = xlApp.ActiveSheet
CurRow = STARTROW
xlSheet.Cells(CurRow, DIMNAMECOL).Value = "Dimension Name"
xlSheet.Cells(CurRow, DIMVALCOL).Value = "Nominal Value"
xlSheet.Cells(CurRow, DIMTOLTYPECOL).Value = "Tolerance Type"
xlSheet.Cells(CurRow, DIMUPPERTOLVALCOL).Value = "Upper Tol"
xlSheet.Cells(CurRow, DIMLOWERTOLVALCOL).Value = "Lower Tol"
xlSheet.Cells(CurRow, DIMTOLFITCLASSCOL).Value = "Fit Class (Hole/shaft)"
CurRow = CurRow + 1
Set swView = swDwg.GetFirstView
While Not (swView Is Nothing)
Set swDispDim = swView.GetFirstDisplayDimension5
While Not swDispDim Is Nothing
Set swDim = swDispDim.GetDimension
swDim.Name = DimNamePfx & DimNameIndex
DimNameIndex = DimNameIndex + 1
Set swTol = swDim.Tolerance
xlSheet.Cells(CurRow, DIMNAMECOL).Value = swDim.FullName
xlSheet.Cells(CurRow, DIMVALCOL).Value = swDim.Value
xlSheet.Cells(CurRow, DIMTOLTYPECOL).Value = GetTolTypeName(swTol, NumTolVals, TolIsFit)
If NumTolVals > 0 Then
xlSheet.Cells(CurRow, DIMUPPERTOLVALCOL).Value = swTol.GetMaxValue * TOLSCALEFACTOR
End If
If NumTolVals > 1 Then
xlSheet.Cells(CurRow, DIMLOWERTOLVALCOL).Value = swTol.GetMinValue * TOLSCALEFACTOR
End If
If TolIsFit Then xlSheet.Cells(CurRow, DIMTOLFITCLASSCOL).Value = swTol.GetHoleFitValue & "/" & swTol.GetShaftFitValue
Set swDispDim = swDispDim.GetNext5
CurRow = CurRow + 1
Wend
Set swView = swView.GetNextView
Wend
xlApp.Range("A:Z").EntireColumn.AutoFit
End Sub
Function GetTolTypeName(ByRef myTol As SldWorks.DimensionTolerance, ByRef NumVals As Integer, ByRef FitTol As Boolean) As String
Dim s As String
FitTol = False
Select Case myTol.Type
Case swTolNONE
s = "None"
NumVals = 0
Case swTolBASIC
s = "Basic"
NumVals = 0
Case swTolBILAT
s = "Bilateral"
NumVals = 2
Case swTolLIMIT
s = "Limit"
NumVals = 2
Case swTolSYMMETRIC
s = "Symmetric"
NumVals = 1
Case swTolMIN
s = "Minimum"
NumVals = 0
Case swTolMAX
s = "Maximum"
NumVals = 0
Case swTolMETRIC
s = "Metric"
NumVals = 2
Case swTolFIT
s = "Fit"
NumVals = 0
FitTol = True
Case swTolFITWITHTOL
s = "Fit With Tolerance"
NumVals = 2
FitTol = True
Case swTolFITTOLONLY
s = "Fit, Tolerance Only"
NumVals = 2
FitTol = False
Case swTolBLOCK
s = "Block"
NumVals = 2
FitTol = False
End Select
GetTolTypeName = s
End Function
Enjoy!
CODE
Dim sCurSuffix As String
Dim nOpenParPos As Long
Dim nCloseParPos As Long
Dim vDimVal As Variant
Dim dInchVal As Double
Dim sInchString As String
Dim sNewSuffix As String
Const DUALFORMAT As String = "0.00"
Dim KillFlag As Integer
Dim sMsg As String
Dim sRefPfx As String
Dim nRefNum As Long
Sub AddDimRefNums()
Exit Sub
End If
sMsg = "This macro will add a text suffix of a dimension reference number " & _
vbCrLf & "to all dimensions in this drawing." & vbCrLf & vbCrLf & _
"To add or update dimension reference numbers inside ""[ ]"", choose ""Yes""" & vbCrLf & _
"To remove all reference numbers, including the ""[ ]"", choose ""No""" & _
vbCrLf & "To quit, choose ""Cancel"""
KillFlag = MsgBox(sMsg, vbYesNoCancel, "Dimension Reference Numbers")
If KillFlag = vbCancel Then
Exit Sub
End If
sRefPfx = InputBox("Please enter the reference prefix")
Set swDwg = swDoc
nRefNum = 1
sInchString = sRefPfx & nRefNum
nRefNum = nRefNum + 1
sCurSuffix = swDispDim.GetText(swDimensionTextSuffix)
nOpenParPos = InStr(1, sCurSuffix, "[", vbTextCompare)
nCloseParPos = InStr(1, sCurSuffix, "]", vbTextCompare)
If (KillFlag = vbNo) And (nOpenParPos > 0) And (nCloseParPos > 0) Then
sNewSuffix = Left(sCurSuffix, nOpenParPos - 1)
sNewSuffix = sNewSuffix & Right(sCurSuffix, Len(sCurSuffix) - nCloseParPos)
ElseIf (nOpenParPos > 0) And (nCloseParPos > 0) Then
sNewSuffix = Left(sCurSuffix, nOpenParPos)
sNewSuffix = sNewSuffix & sInchString
sNewSuffix = sNewSuffix & Right(sCurSuffix, Len(sCurSuffix) - (nCloseParPos - 1))
Else
If KillFlag <> vbNo Then
sNewSuffix = "[" & sInchString & "] " & sCurSuffix
Else
sNewSuffix = sCurSuffix
End If
End If
swDispDim.SetText swDimensionTextSuffix, sNewSuffix
Wend
Wend
End Sub
