Hole Callout Annotation not working?
I am trying to make a hole callout on a drawing I am working on and its just not working. I click on the hole that I want the callout on and all the prog. pops up a little flag next to the arrow which says "pick an edge of a hole". Well, I am picking the edge of a hole and its working fine. If i try the same thing on teh reverse side of the surface the hole callouts work fine.
I dont know what is going on and I am ready to print it out and write the damned hole callouts on it.
Adam
Adam
RE: Hole Callout Annotation not working?
I had some problems with the hole call out function that were discussed in this thread:
thread559-182557: Hole Callout on Curved Surface
I am not sure that this will help but at least it is a start.
Brian
Brian
SW 2006 SP 4.1
I would suggest you not modify or type in dimensions. Our rule is to never, ever text edit a dimension. We had a new guy do just that. Someone else sometime later copied the part, changed it a little then made the drawing. The hole that was text edited did not get dimensioned correctly. Cost us an ECN and shop rework time.
If SolidWorks is not dimensioning the way it should try fixing it, if you cannot fix it, then get your VAR involved.
In the future put your hole wizard holes on the same side you plan to dimension.
Good luck,
Bradley
SolidWorks Premim 2007 x64 SP4.0
PDM Works, Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB, nVidia 3400
Is the edge your picking on a curved surface, or at an angle to the face you're having problems with? If so, SW has trouble recognizing it as a hole.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Thanks for the advice. The part I am dimensioning is not a critical part. I realize that unlinking the dimensions from the part is a bad thing to do.
In this case, the part is merely a demonstration piece that needs to have a few holes punched in it.
No the hole is on a flat surface. I dont know what the problems is
Bradley,
The hole wizard holes were done so that they were on the dimensioned side. It still woudlnt pick up th edge of the hole. It did fine on the reverse side of the surface though...
Thanks for the help with this guys.
Adam
