building a private road
I want to build a private road on some land I own. I want to rent a backhoe and do it myself. This is in Michigan. How should I begin
Matt
myfletcher@prodigy.net
Matt
RE: building a private road
You need to check with the appropriate local entity. I work for a county engineering department and this type of activity is regulated by our department and requires permitting. You didn't state what the road was for, this may affect your design as well as regulations to which you may have to adhear.
Beyond that, the previous advice is sound.
