Solidworks Toolbox question
Using the add my parts wizard, I created a folder under washers called company washers. I did this as a test to see how this feature would work. I was able to locate the files that I wanted to include and use them in my assemblies. How ever the location and components in this folder are not as we want them to be. How do I delete this folder and Its contents from the solidworks toolbox. When I right click on the folder there is no option to delete. When I select the folder and hit the delete button nothing happens. Please help.
RE: Solidworks Toolbox question
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Jeff Mirisola, CSWP
CAD Administrator
Click Options on the Standard toolbar, or click Tools, Options.
On the System Options tab, click Data Options.
Click Edit Standards Data.
On the Access Control tab, under Security, click Create/Change to create a password. In the future, after you create a password, click Login to enter the password to gain user access control.
You enter a secret question when you add a password. If you forget your password, the application prompts you with your secret question. If you answer correctly, you are given the password.
Under User Access Control, select:
Allow editing of standards data. When cleared, the data on the Edit Data tab of the Configure Data dialog box is view only.
Allow configuring of Toolbox. When cleared, the options on the Browser tab of the Configure Browser dialog box in Toolbox are view only.
Allow configuring of Smart Fasteners. When cleared, the options on the Smart Fasteners tab of the Configure Browser dialog box in Toolbox are view only.
Allow usage of Add My Parts Wizard. When checked, you cannot add parts to the library of Toolbox components.
Click OK.
Thanks for posting the fix, though!
Jeff Mirisola, CSWP
CAD Administrator
