looking for a high torque 5 or 6 spd automatic
does anyone make/modify a 5 or 6 spd automatic transmission to handle 1000 plus horsepower...they make the 4 spds...i have one.a modified 4l80e....looking for a 5 or 6 spd..
RE: looking for a high torque 5 or 6 spd automatic
Mike Halloran
Pembroke Pines, FL, USA
As far as a modified version goes, there maybe some performance transmission shops that have some mods for them. Usually it takes awhile for the aftermarket manufactures to come up with performance parts. Anyone modifying them would need the machines to fabricate any special parts required. Hope fully alot of parts from something like the 4L80 would interchange. Items that are usually needed to beef up an automatic are input and output shafts, reaction shell, planetary gear sets, bands and clutch packs /pistons, pump, sprags and roller clutches, then of course valve body modifications. Not known for sure, but maybe things like the clutches, and some gear sets maybe interchangable between the two.
Sounds like a fun project. I think an allison would be too heavy if this a race car application.
Norm
The 6L80e is destined to be used in a wide variety of vehicles with very few mechanical changes. That's why the ECU is inside the transmission and supposedly very programmable. Time will tell.
