Sizing a psv on a pump discharge line
With all things I have done as an engineer, I have never sized a psv.
This psv is on the discharge of a 2x1 centrifugal pump that circulates hot water in a closed system to provide heat to a couple of jacketed vessels then back to and through a small hydronic boiler. Temp of product is 45 degrees C +/- 5 degrees C. Psv on the boiler is set at 45 psi.
How do I size and select the psv on the discharge of the pump?
I suscribe to the statement that the only dumb question is the one you don't ask. I'm asking.
9751jld
9751jld
RE: Sizing a psv on a pump discharge line
With all this said, I think the answer to your question would be protection of the integrity of the jacket and shell. There is no evidence from inspection inside the vessels that baffles were installed with the installation of the jacket(s).
Plans are to blanket the product with dry instrument air at 2 psi just to keep out moisture, and the PSV on the vessels are to be set just above this...at least that is the current plan. Sizing the vessel PSV's, to me, would be based on the charge rate of the product when filling/refilling the vessels. This product will be pumped into the vessels, and when level is reached pumps will shut down and hose disconnected to fill line.
I apologize for being so wordy, but I hope I have answred you question.
9751jld
