2nd speed reducer
2nd speed reducer
2nd speed reducer
For a 56c 1725 rpm 1hp motor, we have a 60:1 motor mounted speed reducer. We would like to go to 100:1 but are having trouble finding one.  Anyone have any qualms about going 20:1 motor mounted with a 5:1 in-line after it?
War stories, tips, or thoughts are appreciated.
ZCP
www.phoenix-engineer.com
RE: 2nd speed reducer
The only thing that I can mention is the efficiency which will reduce with two reducer so the input power needed will increase.
Cheers
Are you certain you cannot get a suitable gearmotor?
My experience with a couple of gearmotor manufacturers tells me they will cobble up almost any combination of 2-, 4-, 6-, or 8-pole motor and gearset combination to provide a customer with his specified output shaft torque and RPM.
HINT:  the catalogs list less than half of the possible gear ratio combinations available for a particular gearbox size and motor size.  Call the distributor and tell them your gearmotor specs, they'll call the manufacturer to get the correct item to suit your needs.
TygerDawg
Blue Technik LLC
Advanced Robotics & Automation Engineering
www.bluetechnik.com
tygerdawg
Already have the motors.  This is for six identical setups and unfortunately the motors are sitting on the skid on the shop floor....we are looking into the other options (such as whole new setups), but want to make sure the 'use the motors we have' stone has been well turned.....
Allen4
Efficiency and space seem to be the two that jump out. Looking for any experiences that bring up other issues....
ZCP
Well, then, if you have the motors already...that's OK I guess.  If you are prepared to purchase new gearboxes, then my previous statement still stands.  SEW Eurodrive will sell you gearboxes with C-Face mounts, coupling mounts, shaft inputs, all kinds of things to mount existing motors.  I suppose Dodge will, too.  And Nord, Falk, etc.  Gear ratio availability is extensive.
But of course, you can double up with a second gearbox, no problem.  Just do the math (which can usually be found in most gearmotor manufacturers catalogs).  You should be calling somebody's Applications Engineering department to get straight answers to your questions.
TygerDawg
Blue Technik LLC
www.bluetechnik.com
