Cut list length issue
Hi All,
I have a 2 cut list items, and I want to link their Length cut-list property to an equation parameter that is linked to a dimension.
ie. length = "d1@sketch3"
then
cut-list property: Length = length@@@cut-list-1@Weldment....
This works fine for me, but it only works on the first cut-list item. My second entry (plateL) just outputs the parameter link: "plateL@@@cut-list-1@Weldment.." instead of the value of the parameter?
Am I only able to link 1 cut-list item to a parameter?
Do I have to create each part as a Structural profile to be able to extract the lengths?
60% of the time, it works every time.
RE: Cut list length issue
The 2nd cut list item was created using a Boss/Extrude and not a Weldment feature, right?
If so, you need to do a right mouse button on the 2nd cut list item and manually add the properties for length etc.
Hope this helps,
