How can I copy SW custom properties to file open detail properties
In PDMWorks my files are now listed using my new dumb Filename, number, description, & DetailNo structure.
Example:
000015.SLDASM <303P> <Die Layout> <117>
This is wonderful for PDMW database structure and selecting files to Check-out.
But when I'm working from my local drive and I want to open a file all I see is a ton of dumb file names.
So here is my question;
How can I map or copy the same SW custom properties viewed in PDMWorks to the "details" column headings properties in a file open dialog box? is there a macro or some VB way?
Note: When you go to open a file, RMB on a column heading it brings up a details list. In the list are a ton of property fields that I can turn on or off. I thought this would be a perfect way to view the same info when opening a file as I do for checking out a file in PDMWorks.
Thanks for any help
Tom
Example:
Thanks for any help
Tom
Tom Malinski
http://www.okayind.com/
Dell Prec 670, Xeon 3.8,2GB Ram, Nvidia Quadra FX 3450/4000 SDI
SWorks Pro & PDMWorks 2007 SP3.0
