Feature control frame positioning
I had a question posed to me. Can a feature control frame be place at an angle or is it a standard to be placed in the horizontal position?
If there is a standard, what is the reference (ANSI, ISO, etc.)?
RE: Feature control frame positioning
rgmcneil,
ASME Y14.5M-1994 covers this in paragraph 1.7.5. Notes and dimensions (non-baseline) should all be written to be "read from the bottom of the drawing".  This means, if you hold the drawing in front of you on a table (for example), with the bottom edge nearest to you, then the dimensions must be readable from that direction.  When ASME Y14.5M-1994 refers to "dimensions", it means all forms of dimensions not specifically excluded in the statement.  So, this also applies to GD&T feature control frames.
Placement of the feature control frame is controlled by paragraph 3.5 of the ASME Y14.5-1994 standard.  It may be below or attached to a leader-directed callout or dimension pertaining to the feature; running a leader from the frame to the feature (similar to leader notes), attaching a side or an end of the frame to an extension line from the feature, provided it is a plane surface; or attaching to the side or end of the frame to an extension line of a dimension line pertaining to the feature of size.
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
Thanks Matt. Just what I was looking for.
