Need to locate a supplier for 10mm anodized aluminum shafting
I have a requirement for 10mm hard anodized aluminum shafting for linear bearing purposes and need to find suppliers.
So far I've only found one, I'm hoping there are others.
QB
QB
RE: Need to locate a supplier for 10mm anodized aluminum shafting
www.igus.com has AL shaft stock.
You might look at Mizumi also.
TygerDawg
Blue Technik LLC
Advanced Robotics & Automation Engineering
www.bluetechnik.com
QB
www.aacoa.com
