water resistant connector
Does anyone know of a light weight, water-resistant bulkhead connector that's fairly inexpensive? Thanks.
RE: water resistant connector
To carry what? Anyone from Cavotec for heavy power connectors to Lemo for small signal. You question is basically useless unless you give us more information.
  Sometimes I only open my mouth to swap feet...
Need a little more information:
Current range, Voltage, Wire size, and market (automotive, consumer electronics, HVAC Utility, military (aircraft, submarine), aerospace). Also, volume you might use - affects up-front costs, tooling, or possible custom/semicustom sources (choices are different if you want 1 or you are needing 100,000).
