CNC and welder on same feed
Any opinions on negative effects to putting a cnc milling center and a mig welder on the same feeder. Both are 460 volts and about 40 amps each. We want to put them on a 100 amp feeder. The welder won't be run that much a few hours a day here and there. Thanks
RE: CNC and welder on same feed
Very hard call... It really depends on the engineered-in quality of the two pieces of equipment.  You could have no problem, or you could have lots of problems.
Generally those two relatively 'noisy' devices would be better not  sharing.
If you must I would consider using some serious, quality filters in series with each, individually.
Keith Cress
