ASTM A515 GR. 70
ASTM A515 GR. 70
Grettings everyone.
I would like to know if some can bring me some information about this material, mechanical properties, chemical composition and the kind of applications in vessel pressures.
Something like tha range of pressure, temperature and conditions, where I should use this plate steel material.
Thank you.
I will appreciate your help.
Thank you.
RE: ASTM A515 GR. 70
Are you talking about A-516 Grade 70?
GO TO
http:/
http://
http:
LUISMARQUES
ultimate tensile strength. The minimum yield strength is 38 ksi(260 MPa. Plates over 2" thick must be normalized. The steel shall be silicon killed (fully deoxidized) and made to coarse grain size practice.
A-515 is preferred for use at operating temperatures above 650 F. It is not recommended for use in low temperature applications.
