Toolbox Part - Conversion Back To Standard Part
I have a model of a cap head socket screw (with configurations) which is used directly from our toolbox part library.
When an assembly containing it is checked in, this item shows up as a toolbox reference only which is what I want it to do.
However I needed to use a cap head screw with a modified thread, so I copied the toolbox one and deleted all the configurations apart from the size I needed, then made the modification and saved it as a brand new part.
When I check in the assembly it still shows up as being a toolbox reference and the part remains in my workspace NOT checked in.
My question is:- How can I tell this new part that it is no longer a toolbox part and to act just like any other manufactured part and make its way into the PDM vault.
Phil
Phil
RE: Toolbox Part - Conversion Back To Standard Part
Run this program:
C:\Program Files\SolidWorks 2007\Toolbox\data utilities\sldsetdocprop.exe
It can convert a toolbox part to a non-toolbox part and vise-versa.
cheers,
This Property plays a vital role in PDMworks and has caused some people more harm then they initially thought it might.
But understanding this function was the key to fixing that problem.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
I would never have found that.
It worked a treat once I realised that I had to log in as admin and delete the original assembly from the vault.
Prior to that I got Vault Error 102 on check in
Phil
