Scaling Decals
Scaling Decals
When working with decals, do you have to get the image to scale before you bring it in as a decal, or can you scale it within Photoworks? I would like to apply an image I took of some polished aluminum treadplate to a plate, but when I bring it into Photoworks it is not the correct scale.
Thank you,
Jack
Thank you,
Jack
RE: Scaling Decals
I´ll split it in 2.
First- You must not give the scale for your picture. It apply perfect in the perfect scale to your part.
Second- You took the image of polished aluminum treadplate to a plate. It is not in the correct scale because it´s not configure yet. Select the entire part, or a face. Then click the icon "Materials". Select a kind of material. Then, in the Tab "Displacement", select the right scale.
Sorry about the language, I am Portuguese (Brazil).
Hope that helps.
RE: Scaling Decals
Thanks.
RE: Scaling Decals
I do not have that much experience with PW. I took a digital image of a piece of aluminum treadplate. When I apply this image to my plate in PW, the number of diamonds per inch is not accurate. I didn't know whether I needed to adjust the image before I brought it into PW or if I can adjust it within PW. Hope this explains my question better.
Thanks for the help!
Jack
RE: Scaling Decals
Why you dont use the models of aluminum treadplate of SW?
Then you can set the right scale.
Althoug, if you want to export the picture, try to change the scale when you export it. Inside the SW, you can´t do that. Only with the SW´s defaults.
My preference is try to use the defaults of SW, it´s much more better.
