DGN settings Microstation J
I am working on a R.O.W. map and certain sheets will show my solid objects as being a solid. All of my reference files will also show solid objects as being solid (graphically and also when I plot). However there are two that will only show the outlines of the solid objects. Some of these objects are in the other DGNs and graphically show correctly (ie: title block). Is there a setting that is turned off or an attribute that is incorrect that I can change to plot these objects correctly? Also, on these same sheets, the hatching pattern plots heavier than on other sheets. Is there something I can compare in the other DGNs to correct these settings?
RE: DGN settings Microstation J
