valve throttling
valve throttling
valve throttling
I have a butterfly valve in a recirc line throttled back,on the Discharge side, on that valve it is tagged to keep closed 5 "clicks", what purpose would this serve? Water is the element for a scrubber system.
RE: valve throttling
A wild guess is that the pump curve is not well suited to the piping system.  Perhaps the valve attempts to make a bad pump selection workable.
It might be to create a DP in the flow path.
