Materials Capable of Withstanding 420,000 PPM H2S
Any recommendations of high strength (90 ksi or so) materials capable of withstanding 420,000 PPM (42 %) H2S and 8 % CO2 at 400 degrees F (bottom hole temperature) at 17,000 psi pressure (bottom hole pressure) for an oilfield downhole application? We typically use 4140 HT or 17-4 PH stainless at H900 condition for our downhole tools, but these will become hydrogen embrittled. Thanks in advance for any ideas!
RE: Materials Capable of Withstanding 420,000 PPM H2S
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
The first question to ask is: will these tools see any liquid water? The second is: are there any chlorides around? The third is: any elemental sulphur?
Armed with that knowledge, one can then look at ISO 15156.
Steve Jones
http://www.pdo.co.om/pdo/
The "C" alloys are probably not strong enough. Age-hardening of Inconel 625 is one option you can try out.
Detailed materials and fabrication guidance can be found in NACE Publication 8X194.
luis marques
