Remove sulfur contaminants from liquid paraffin?
What is the best way to remove sulfur contamination from an otherwise relatively pure stream of liquid paraffin (about 135 m3/hr)?
RE: Remove sulfur contaminants from liquid paraffin?
What type of sulfur compounds ? 135 cubm/h on a continuous basis ?
I forgot to ask what level of contamination ?
The 135 m3/h paraffin on a continuous basis. About 5-10 ppm. I am waiting for some analysis results to determine sulfur is present in which form. I should have results tomorrow. I'll fill you in on this.
