Assembly components being randomly hidden in drawings
I have a recurring problem with drawings I haven't accessed for several months:
When I open a drawing, some components are hidden in the drawing, even if all components are shown in the Assembly. To show them, I have to locate them in the feature tree and RMB -> Show/Hide -> Show Component.
Is there a way to prevent this from happening, and if not, is there a quick way to "show all" components in drawing views, similar to "show with dependents" in assembly mode?
TIA
TIA
RE: Assembly components being randomly hidden in drawings
Did you check the Hide/Show Tab of the Drawing view (RMB the view, Properties) to see if it's hidden there? If they are placed in there they will be hidden and you can simply RMB the pink window and clear all and select OK.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
Of course, Scott's solution works great.
