SW 2K7 - Surface Trimming Problem
My company just upgraded to 2k7 SP4 and now I am unable to use the surfacing trim or extend feature. When I try to do it it says it cannot do it because their is rebuild errors.
Completely stuck, 50% of my job is using surfaces and if I can't do this I am in deep water.
Any thoughts? Has anyone else run into this problem?
RE: SW 2K7 - Surface Trimming Problem
Dan
www.eltronresearch.com
If you upgraded, you shouldn't do that... you should always do a new install. For that not to work is a pretty major issue and would have had a .1 SP released by now to fix that. I think its something you might be doing or its your install. I would do one of 2 things... Reinstall as a new install and clean out the Registry or just try the alternative reinstall. - FAQ559-507: Alternative to try before reinstalling
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
