creating a tri-mesh from points acad 2008
I have a drawing with points and I have been asked to creat a tri-mesh for AGTEK to read. Is this possible and if so How?
RE: creating a tri-mesh from points acad 2008
I have never used AGTEK, but I'm guessing they want you to create a surface from the points. You can do this if you have Autodesk Land Desktop, but I don't believe you could with straight AutoCAD.
I guess I should've asked... Are you running straight AutoCAD or one of the specialized versions such as Land Desktop?
TY both I am running reg autocad 2008. I didnt think it was possible now I have confirmation.
John
Check your email.  I sent you a link to a program that runs inside autocad.  I'm not sure how Agtek will read the file.
