Nozzle Discharge Pressure
I 'd like to inject chemical to 16"pipeline pressure 400 psi, what pressure 'd I have to supply to the nozzle ? and could u pls suggest me some nozzle vendors.
RE: Nozzle Discharge Pressure
The PD pump also have the advantage of beeing a metering pump. That is that when the pump are at a certain rpm it will deliver a certain volume/time unit.
Best Regards
Morten
Any pressure above 400 psi would be ok in your case. Instead of nozzles, as suggested by MortenA dosing pump could be a better option, where you can have control on the amount of dosing at minute levels and can be automated too if required. But take care that dosing pump should pump at more pressure than 400 psi.
I've some information about PD pump (Plunger Pump) but the problem I have is I can't find nozzle that has Male Pipe Thread at the nozzle tip since I have available threadolet vent 3/4" or 1 1/2" and 'ld like to use it as injection port. Could u pls suggest any websites
Have you ever heard about google? Its a search engine - try it out. Maybe one time before posting your question?. I used the ost logical search words: "Chemical injection nozzle" and the top threeitems looked great. This is the third on the list:
http://www.betzdearborn.com/ind_app_prod/product_family.asp?Prod_id=801
Maybe that will work?
Best Regards
Morten
