Stress at particular strain
Hello users,
 How to get stress values at particular strain or displacement like 5%, 10%, 15% and so on.
 In my compression analysis, i get results randomly.
 I use abaqus CAE.
 Thanks for your time and help.
feaplastic
RE: Stress at particular strain
If the analysis is within the elastic regime and the geometry is not non-linear then the results will be directly proportional to your input displacement Otherwise you'd have to plot the stresses as the displacement increased.
I have no idea how you can get apparently random results from a model.
corus
Hi feaplastic,
I am not sure that I can exactly understand your question. But users can obtained the evolution of the stress/strain at particular integration point of an element from either history or field data.
Ehm... what do you mean by random results ?
regards.
I think you may control your increment size.
as Louisa said, decrease the increment to a smaller time by fixing the minimum increment time to a small value
random results means - i get stress results at 3%,7%,11% ...  strain.
But i need, exactly at 5%, 10%,.. and so on.
I tried minimizing time increment. But, no success.
I have non-linear geometry on and material curve also highly non-linear.
I read somewhere, it is possible only for linear analysis.
For non-linear, it must be extrapolated from existing values.
is it true?
Thanks for time and help. Excuse me for late reply.
feaplastic
What u need to do is to fix the maximum increment size to a very small number and hope that your stress results will fall closely to the strain u want.
hi feaplastic.
If you mean that you wish to display the strain plots at 5%, 10% etc, you can go to the contour options and change the limit from auto compute to 5% (or whichever strain value you like).
You can try what Yoman suggested, but with non-linear material it is really unpredictable and you will lengthen solution time. You can make displacement/load/temp increase ramp as you like by editing increment specs, but strain is a behavior dictated by inherent material property.
That's all I can offer. Hope this helps.
regards,
jo
