Failure of cable outersheath: 3 core cables laid buried in ground
I have come across failure of a 3cx240sqmm, 1000V rated, armoured, XLPE insulated, PVC outersheathed power cables recently. The failure shows that the PVC outersheath over the armour is peeled off.
This has happened after about one year in service. Can this be some thing to do with the outersheath material composition!
Thanks.
Thanks.
RE: Failure of cable outersheath: 3 core cables laid buried in ground
