Ansys_ load case combination-basic query
hi all,
I am new to Ansys and have the following questions.
I am doing structural static nonlinear analysis with 3 load cases
1.How can I define the 3 load conditions as a seperate load steps. Should I need to do Ls clear before defining the load conditions.
2. How to define the load case comination with factors in Post processing mode.
Can some one help me in implimenting the above points in Ansys
Thanks in advance
Thanks in advance
RE: Ansys_ load case combination-basic query
In the name of good book keeping I usually construct load step files where the first command is LSCLEAR,ALL and then reapply all my boundary conditions. This works best for me. Use whichever approach works best for you.
rh142 hits a good point: of course, non-linearity makes superposition of effects fall apart and thus any loadcase combination will be meaningful.
