PD levels in cast-resin dry type transformers
Is there any reference / standard for allowable partial discharges (in pico coulombs) for cast-resin dry type transformers ? I am looking for PD values for 11 KV/433 V, 500 KVA Trafos.
Thanks in advance.
*Why a man thinks he outrun a chasing dog when it has twice as many legs?*
RE: PD levels in cast-resin dry type transformers
Depends on where you're coming from, but in IEC 60076-11:2004, the level is 10pC at 1.3Urated.
Thanks ausphil. IEC is fine.
When you say 1.3 U rated, shall I take it as the line-to-line voltage and not phase voltage ?
Any temperature limit while measuring the pd ?
