Bulk Modulus of Sulphuric Acid 98%
Please advise any source where I would find the bulk modulus of 98% sulphuric acid. I have search the Internet but to no avail.
Many thanks
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
RE: Bulk Modulus of Sulphuric Acid 98%
Find the density and sound velocity and estimate the value of the volumetric elastic modulus.
My estimate from the data at 20oC is ~3×108 kg/m2.
I have the density for a range of temperatures. Does the sound velocity vary with temperature? If so can you please advise where I can find such data?
Here are two references to the speed of sound in H2SO4.  There may be enough data in the first reference to generate another set of curves from the three data sets plotted.
This is about a 2.5 MB downlaod.
http://www.kor-tech.co.kr/cgi-bin/technote/main.cgi/Ternary_liquids_analysis.pdf?down_num=1118797975&board=board2&command=down_load&d=&filename=Ternary_liquids_analysis.pdf
http://www.rshydro.co.uk/sound-speeds.shtml
